Issue with CFX solver in Learning Hub’s WS01-Mixing-Tee exercise
    • Risto86
      I'm attempting to make my way through some of the learning hub courses as I await my university to license our sponsored software package, using the free student edition in the meantime.
      I've gone through this exercise numerous times, starting from scratch twice, and I continue to get the error notices "Non-zero exit code 2" and on the CFX solver outfile, "Solver exited with return code 1".
      My understanding is that the student version has a node/element limit of 152k, which was never approached but I still received the error. I went back and applied mesh sizing limits to reduce the mesh to below 32k and I still receive the error.
      Is the issue a misapplication somewhere in the meshing or setup process? An issue with my computer, or simply that I'll need to have the licensed academic version to run the solver on this problem?
      Attached file note: v0 is before mesh adjustment, v1 is after using sizing to reduce element count.
      Will update if I find a solution before someone responds.
      Thanks!
      You've got a 512k cell count limit, so should be fine with the tutorials. Are there any warnings/messages before the exit code? Those tend to be more useful. Also check disc space both in the working directory but also scratch (set in Workbench -> Tools).
    • DrAmine
      Are you seeing any license error messages in the CFX out file?
    • Risto86
      I recorded my desktop as I ran the solver so you can see what I see. I've also attached the CFX solver out file as copied into notepad, which does show a warning on the top which I don't understand. I monitored my computer cpu usage and memory during a subsequent run, and it didn't get anywhere near maxed out. (edit with attached mp4 pending)
      Within (tell me if this is the right place to look to check disc space) Workbench->Tools->Options->Mechanical ADPL->Default Memory: 1024mb; Workspace Memory: 1048mb.
      I haven't seen any notice of license errors in the outfile, unless I somehow overlooked it multiple times
      For the disc space just use the File Manager/Explorer and check for free space.  As staff we can't open attachments so can't review the out file.
    • Risto86
      That's unfortunate, I'll take it the video will be a waste to upload... I have 676 GB of free space on my computer
      The warning at the top of the file is "Warning! Revision is over 16 characters long 39"
      Then at the bottom I see: "An error has occurred in cfx5solve: The ANSYS CFX solver exited with return code 1. No results file has been created."
      Full out file as below:
      Warning!
       This run of the CFX Welcome to ANSYS Student Discovery Live Solver
       started at 02:55:06 on 12 Feb 2019 by user risto on DESKTOP-17EOLLP
       (intel_xeon64.sse2_winnt) using the command:
        "C:Program FilesANSYS IncANSYS Studentv192CFXbinperllibcfx5solve.pl"
          -batch -ccl runInput.ccl -fullname CFX_003
        Point Releases and Patches installed:
        Academic Student Release 19.2
        FENSAP-ICE Release 19.2
        AIM Academic Student Release 19.2
        AIM Release 19.2
        Discovery Release
       Setting up CFX Solver run ...
      CFX Command Language for Run
       LIBRARY:
         MATERIAL: Water
           Material Description = Water (liquid)
           Material Group = Water Data, Constant Property Liquids
           Option = Pure Substance
           Thermodynamic State = Liquid
           PROPERTIES:
             Option = General Material
             EQUATION OF STATE:
               Density = 997.0 [kg m^-3]
               Molar Mass = 18.02 [kg kmol^-1]
               Option = Value
             END
             SPECIFIC HEAT CAPACITY:
               Option = Value
               Specific Heat Capacity = 4181.7 [J kg^-1 K^-1]
               Specific Heat Type = Constant Pressure
             END
             REFERENCE STATE:
               Option = Specified Point
               Reference Pressure = 1 [atm]
               Reference Specific Enthalpy = 0.0 [J/kg]
               Reference Specific Entropy = 0.0 [J/kg/K]
               Reference Temperature = 25 [C]
             END
             DYNAMIC VISCOSITY:
               Dynamic Viscosity = 8.899E-4 [kg m^-1 s^-1]
               Option = Value
             END
             THERMAL CONDUCTIVITY:
               Option = Value
               Thermal Conductivity = 0.6069 [W m^-1 K^-1]
             END
             ABSORPTION COEFFICIENT:
               Absorption Coefficient = 1.0 [m^-1]
               Option = Value
             END
             SCATTERING COEFFICIENT:
               Option = Value
               Scattering Coefficient = 0.0 [m^-1]
             END
             REFRACTIVE INDEX:
               Option = Value
               Refractive Index = 1.0 [m m^-1]
             END
             THERMAL EXPANSIVITY:
               Option = Value
               Thermal Expansivity = 2.57E-04 [K^-1]
             END
           END
         END
       END
       FLOW: Flow Analysis 1
         SOLUTION UNITS:
           Angle Units = [rad]
           Length Units = [m]
           Mass Units = [kg]
           Solid Angle Units = [sr]
           Temperature Units = [K]
           Time Units =
         END
         ANALYSIS TYPE:
           Option = Steady State
           EXTERNAL SOLVER COUPLING:
             Option = None
           END
         END
         DOMAIN: junction
           Coord Frame = Coord 0
           Domain Type = Fluid
           Location = Fluid Domain
           BOUNDARY: inlety
             Boundary Type = INLET
             Location = inlet y
             BOUNDARY CONDITIONS:
               FLOW REGIME:
                 Option = Subsonic
               END
               HEAT TRANSFER:
                 Option = Static Temperature
                 Static Temperature = 10 [C]
               END
               MASS AND MOMENTUM:
                 Normal Speed = 5 [m s^-1]
                 Option = Normal Speed
               END
               TURBULENCE:
                 Option = Medium Intensity and Eddy Viscosity Ratio
               END
             END
           END
           BOUNDARY: inletz
             Location = inlet z
               FLOW REGIME:
                 Option = Subsonic
               END
               HEAT TRANSFER:
                 Static Temperature = 90 [C]
               END
               MASS AND MOMENTUM:
                 Normal Speed = 3 [m s^-1]
               END
               TURBULENCE:
               END
             END
           END
           BOUNDARY: outlet
             Boundary Type = OUTLET
             Location = outlet
               FLOW REGIME:
                 Option = Subsonic
               END
               MASS AND MOMENTUM:
                 Option = Average Static Pressure
                 Pressure Profile Blend = 0.05
                 Relative Pressure = 0 [Pa]
               END
               PRESSURE AVERAGING:
                 Option = Average Over Whole Outlet
               END
             END
           END
           BOUNDARY: wall
             Boundary Type = WALL
             Location = F29.40,F30.40,F31.40,F32.40,F33.40
               HEAT TRANSFER:
                 Option = Adiabatic
               END
               MASS AND MOMENTUM:
                 Option = No Slip Wall
               END
               WALL ROUGHNESS:
                 Option = Smooth Wall
               END
             END
           END
           DOMAIN MODELS:
             BUOYANCY MODEL:
               Option = Non Buoyant
             END
             DOMAIN MOTION:
               Option = Stationary
             END
             MESH DEFORMATION:
               Option = None
             END
             REFERENCE PRESSURE:
             END
           END
           FLUID DEFINITION: Fluid 1
             Material = Water
             Option = Material Library
             MORPHOLOGY:
               Option = Continuous Fluid
             END
           END
           FLUID MODELS:
             COMBUSTION MODEL:
               Option = None
             END
             HEAT TRANSFER MODEL:
               Option = Thermal Energy
             END
             THERMAL RADIATION MODEL:
               Option = None
             END
             TURBULENCE MODEL:
               Option = k epsilon
             END
             TURBULENT WALL FUNCTIONS:
               Option = Scalable
             END
           END
         END
         OUTPUT CONTROL:
           MONITOR OBJECTS:
             MONITOR BALANCES:
               Option = Full
             END
             MONITOR FORCES:
               Option = Full
             END
             MONITOR PARTICLES:
               Option = Full
             END
             MONITOR POINT: p inlety
               Expression Value = areaAve(Pressure )@inlety
               Option = Expression
             END
             MONITOR POINT: p inletz
               Expression Value = areaAve(Pressure )@inletz
               Option = Expression
             END
             MONITOR RESIDUALS:
               Option = Full
             END
             MONITOR TOTALS:
               Option = Full
             END
           END
           RESULTS:
             File Compression Level = Default
             Option = Standard
           END
         END
         SOLVER CONTROL:
           Turbulence Numerics = First Order
           ADVECTION SCHEME:
             Option = High Resolution
           END
           CONVERGENCE CONTROL:
             Length Scale Option = Conservative
             Maximum Number of Iterations = 100
             Minimum Number of Iterations = 1
             Timescale Control = Auto Timescale
             Timescale Factor = 1.0
           END
           CONVERGENCE CRITERIA:
             Residual Target = 1.E-4
             Residual Type = RMS
           END
           DYNAMIC MODEL CONTROL:
             Global Dynamic Model Control = On
           END
         END
       END
       COMMAND FILE:
         Version = 19.2
         Results Version = 19.2
       END
       SIMULATION CONTROL:
         EXECUTION CONTROL:
           EXECUTABLE SELECTION:
             Double Precision = No
             Large Problem = No
           END
           INTERPOLATOR STEP CONTROL:
             Runtime Priority = Standard
             MEMORY CONTROL:
               Memory Allocation Factor = 1.0
             END
           END
           PARALLEL HOST LIBRARY:
             HOST DEFINITION: desktop17eollp
               Remote Host Name = DESKTOP-17EOLLP
               Host Architecture String = winnt-amd64
               Installation Root = C:Program FilesANSYS IncANSYS Studentv%vCFX
             END
           END
           PARTITIONER STEP CONTROL:
             Multidomain Option = Automatic
             MEMORY CONTROL:
             END
             PARTITION SMOOTHING:
               Maximum Partition Smoothing Sweeps = 100
               Option = Smooth
             END
             PARTITIONING TYPE:
               MeTiS Type = k-way
               Option = MeTiS
               Partition Size Rule = Automatic
             END
           END
           RUN DEFINITION:
             Run Mode = Full
             Solver Input File = CFX.def
             Solver Results File =
               CUsers/risto/Desktop/WS01-Mixing-Tee_pending/dp0_CFX_Solution/CFX_0
               03.res
           END
           SOLVER STEP CONTROL:
             MEMORY CONTROL:
             END
             PARALLEL ENVIRONMENT:
               Number of Processes = 1
               Start Method = Serial
             END
           END
         END
       END
      Solver
      ANSYS(R) CFX(R) Solver
      End of solution stage.
       For CFX runs launched from Workbench, the final locations of directories
      and files generated may differ from those shown.
      This run of the ANSYS CFX Solver has finished.
    • DrAmine
      Looks consistent: are there any other error messages printed in the CFX console? Can you try running the definition file in CFX Standalone? Can you attached the definition file here?
    • Risto86
      I'm sorry, can you explain what you're asking for, or point me to an explanation of how to do it?
    • DrAmine
      You have a definition file created in the workbench directory (name*.def). Now Start CFX Solver out of the Workbench: Start Programs, CFX, then CFX Solver from the CFX Launcher Panel, define Run, give the path to the definition file and start.
    • Risto86
      I apologize, it took me a couple of days to get back to this.
      I tried your suggestion, and the result is exactly the same in the Solver Manager, but I do have a shell window with this additional output:
      Warning!
      2019/02/14 19:400    INFO                Demo license file C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic exists.
      Warning!
      Unable to assign product revision id.
      Use of uninitialized value $data_items{"Application.Buildinfo"} in sprintf at C:Program FilesANSYS IncANSYS Studentv192CFXbin/perllib/CFX5/Simulation/Configuration/APIP.pm line 119.
      Use of uninitialized value $data_items{"Mesh.Elements"} in sprintf at C:Program FilesANSYS IncANSYS Studentv192CFXbin/perllib/CFX5/Simulation/Configuration/APIP.pm line 119.
      Use of uninitialized value $data_items{"Mesh.Faces"} in sprintf at C:Program FilesANSYS IncANSYS Studentv192CFXbin/perllib/CFX5/Simulation/Configuration/APIP.pm line 119.
      Use of uninitialized value $data_items{"Mesh.Nodes"} in sprintf at C:Program FilesANSYS IncANSYS Studentv192CFXbin/perllib/CFX5/Simulation/Configuration/APIP.pm line 119.
      Use of uninitialized value $data_items{"Mesh.Zones"} in sprintf at C:Program FilesANSYS IncANSYS Studentv192CFXbin/perllib/CFX5/Simulation/Configuration/APIP.pm line 119.
      Use of uninitialized value $data_items{"Session.TotalCpuTime"} in sprintf at C:Program FilesANSYS IncANSYS Studentv192CFXbin/perllib/CFX5/Simulation/Configuration/APIP.pm line 119.
    • DrAmine
      Can you please for debugging purposes create a simple pipe with velocity inlet, wall and pressure outlet, carry out that steady simulation and check if it works. Thanks
    • Risto86
      It seems that there was an issue with the geometry. I created my own version of the tee in SpaceClaim and the simulation ran perfectly!
    • DrAmine
      Nice. Please mark this as resolved.
Viewing 12 reply threads
  • The topic ‘Issue with CFX solver in Learning Hub’s WS01-Mixing-Tee exercise’ is closed to new replies.
