February 6, 2019 at 4:02 pm
fx213
SubscriberTheme: Length of Extrude in ANSYS DesignModeler SketchingÂ
I would like to ask you a question on how we can give dimension to the Extrude we select after Sketching in order to convert our 2D sketch model into 3D dimensional model in DesignModeler.
I have attached two images with the sketch (2nd) and the extruded model (1rst). I do not want the width of the model in the YZ (PLANE) direction to be that large. How can I edit/ change this, giving the Extrude the dimension I want? Do I do that from Sketching as well?
Thank you in advance.
Kind regards,
FX
February 6, 2019 at 4:55 pm
Forum ModeratorExtrude should add an extra panel under the tree, it looks like you're missing something. Clicking on the "Details View" button bottom left may bring it back. If not, on the top menus Tools -> Windows -> Reset layout  to (hopefully) fix the interface.Â
February 7, 2019 at 6:55 am
Keyur Kanade
Ansys Employeeyes, as rob suggsted, please reset layout and then check following tutorial which explains controls under extrude.Â
https://www.youtube.com/watch?v=_N7WXFON_Nc
February 7, 2019 at 2:15 pm
fx213
SubscriberDear Rwoolhou and Kkanade,
Thank you both for your replies.
I figured it out eventually. I determined the dimensions from the Sketching dropdown menus. Thanks for your help.
Kind regards,
FX
February 8, 2019 at 5:39 am
Keyur Kanade
Ansys Employeegood.
can you mark this post as 'is solution' to help others on forum.Â
February 8, 2019 at 10:03 am
fx213
SubscriberYes, of course. Thank you a lot for your help.
FX
- The topic ‘Sketching dimension in Desigh Modeller – Extrude’ is closed to new replies.
5889
1306
