How to create a section for visualization in Fluent
    • AndreaGaggi16
      Hi everyone!
      I have a cylindric volume cooled down under zero degrees and I want to see what is happening inside the volume over time.
      How can I look inside the volume/create a section?
      Maybe it is a simple question but I am an ANSYS beginner, I'm sorry.
      Thank you!
      Andrea
      Create an iso surface of mesh (Post processing tab) for a value that's down the middle of the domain. Display contours, vectors or whatever on that surface.
      If you read through some of the examples/tutorials attached to the R19 documentation they'll give you more details.
    • AndreaGaggi16
      Thank you! I have now made a plane and selected plane 1 for contour 1 but still can't see anything.
      Where can I find those tutorials?
    • Keyur Kanade
      click OFF the boundary zone i.e. wall in model tree.
      you can check following videos.
      https://www.youtube.com/watch?v=Mv7w2PBkf8M
      https://www.youtube.com/watch?v=nUSQxaL4hks
      if this helps you, please mark this post as 'is solution' to help others on forum.
    • AndreaGaggi16
      Thank you very much!
      It seems to be a bug at my computer. Yesterday I switched the wall off and nothing changed. Today I switched the wall off and now I can see the solutions. Strange.
      It's possible you added the wall into the contour plot, it's easily done when learning.
Viewing 5 reply threads
  • The topic ‘How to create a section for visualization in Fluent’ is closed to new replies.
