January 24, 2019 at 7:25 am
MARIUS
SubscriberHello !
I´m doing a coupled simulation using ANSYS Fluent and EDEM. I´m simulating a coating process in a fluidized bed. My question is about the coupling interface.
I want the simulation to solve the flow-field-equations every say (50) timesteps but want to calculate the drag on the paricle for all time.
I was looking in the coupling folder but I didn´t find the right file or how to edit the code. Has someone did that before or an idea how to do it ?
Best Regards
Marius
January 25, 2019 at 3:36 pm
DrAmine
Ansys EmployeeI am highlighting following link from DEM solution regarding the interface and support on it:
https://www.edemsimulation.com/news/dem-solutions-announces-availability-of-new-parallel-edem-cfd-coupling-for-ansys-fluent/
Coupling is done one at the beginning of each time step.You can try switch on / off equations via journaling on the Fluent side.
- The topic ‘Fluent-EDEM coupled simulation’ is closed to new replies.
3717
1313
1163
1090
1014
