January 16, 2019 at 9:59 pm
January 17, 2019 at 12:53 pm
Aniket
Forum ModeratorWorkbench mechanical does not support spherical coordinate systems at the moment.
you can either :
use APDL commands (CS command to create the spherical coordinate System, use the RSYS and /SHOW commands to plot the result your want)
use ACT capabilities to transfer the results from the global coordinate system to the spherical one. However, you will need to create the transformation matrix (there is no function to automatically do it even in ACT)
January 17, 2019 at 2:52 pm
zhihuizou1988
SubscriberThank Aniket very much for your suggestions. One issue is that Ansys WB only offers the following stress plots but not the whole stress tensor with 9 components. Therefore, how can I get the stress sigma_{theta theta} along the polar direction as shown in my last post? In other words, how can I define the proper transformation matrix even with ACT?
January 18, 2019 at 11:07 am
Aniket
Forum ModeratorFor Custom results example you can refer to the following link in the help manual:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v193/act_cust_mech/Von-MisesStressAsACustomResult-31B65E8B.html
If you are not able to access the link check following post for how to access the link above:
- The topic ‘Stress plot on spherical coordinate system in Ansys Workbench’ is closed to new replies.
4838
1587
1386
1242
