Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › ‘.db’ file › Reply To: ‘.db’ file
December 6, 2023 at 2:46 pm
Hi Galaxy,
Thanks for your patience. Will you please answer the following questions so that I can understand the issue properly?
1. May I know your purpose in extracting .db file if saving the archive file doesn't meet your requirement as per your above-mentioned query?
2. What types of analysis are you performing? Please let me know.
3. Can you change the path of the saved file and then try to extract the DB file again?
4. Are you able to extract the DB file for any dummy simple model so that I can understand your issue properly?
Sampat
