Ansys Learning Forum Forums Installation and Licensing Ansys Products The nodal solution for displacement command is not giving me a coloured plot Reply To: The nodal solution for displacement command is not giving me a coloured plot
Daniel Shaw
Is the model constructed using line elements (probably beams)?  If so, you may need to use the /ESHAPE command to show the elements and the contours.
