January 3, 2019 at 6:44 am
swathi
Subscriber I have a problem using CFD-Post: recently, when I'm trying to open certain simulations, it gives me this error:
ERROR
Error reading file "C:.....test.dat". Reason:
FluentIO: Invalid Fluent case
I used to load the same dat file earlier but now it is showing error. Moreover my work is unsteady simulation and IÂ cant run it again now.
Does anybody know what suddenly happens? -
January 3, 2019 at 6:51 am
Keyur Kanade
Ansys Employeeare you able to load case and data file in fluent?
January 3, 2019 at 7:09 am
swathi
Subscriberno. but my all cas and dat files are still in the fluent. files are not gone
January 3, 2019 at 7:17 am
Keyur Kanade
Ansys Employeecan you please export .cdat file from fluent and import in cfd-post.
if this helps you, please mark this post as 'is solution' to help others on forum.
January 3, 2019 at 7:46 am
swathi
Subscriberi have already tried that but that too is not working
January 3, 2019 at 11:09 am
Forum ModeratorThis occurs when the data is no longer compatible with the case file. The usual cause is moving mesh or re-ordering the grid. Are either of these involved?Â
January 3, 2019 at 11:16 am
swathi
SubscriberI didnt do anything with the grid.
January 3, 2019 at 11:55 am
DrAmine
Ansys EmployeeUnzip the case file if zipped and open it in notepad++ look after the time history and check if it corresponds to the transient data created. But anyway the error message usvtellingvtgar test.dat is not valid. The name of the file dies not contain any incremental related to time step or flow time. Are you sure that you are saving data every x steps? Please screenshot showing that.
I guess you will need to rerun or to rexport to Post if Fluent data can be read back into Fluent.
- The topic ‘error in loading dat file’ is closed to new replies.
6570
1311
