December 28, 2018 at 11:55 am
naveen28
SubscriberHi,
I am running an static structural analysis on a plastic part (HIPS material). I am getting varying stress based on their mesh size (used sphere of influence). So, I conducted a mesh independent study and below is the image of it (Also attached the image).
I want to know if the above study is enough to conclude on the mesh size? Please clarify with explanation.
Thanks,
Naveen
December 28, 2018 at 3:08 pm
peteroznewman
SubscriberHi Naveen,
The plot shows evidence of a singularity in your model. Do you have a sharp interior corner?
Please show a zoomed in view of the geometry in the region of the maximum stress.
Read this discussion on Mesh Refinement Study. The plot should level out at small size elements.
December 28, 2018 at 3:21 pm
December 28, 2018 at 4:17 pm
peteroznewman
SubscriberThe geometry has no sharp interior corner, so if there is a singularity, it's not caused by geometry.
Please show the smallest element size on that same view. It might be the case that you just haven't got the element size small enough to converge on the "true" stress.
How is that part being loaded? Is there contact? If so, please show the other part and its mesh.
December 31, 2018 at 8:32 am
December 31, 2018 at 2:16 pm
peteroznewman
SubscriberContinue making new points on the graph, and throw away all the results except for 0.1 and plot the data forÂ
0.01
0.006667
0.004444
0.002963
0.001975
0.001317
These sizes use a factor of 1.5 reduction. When the graph levels out, you can stop plotting points.
- The topic ‘Need clarification while concluding on Mesh Independent Study’ is closed to new replies.
4888
1587
1386
1242
