December 26, 2018 at 3:57 pm
StevenTimoney
SubscriberHello
I am working on a project and need a inflation layer.
In the picture you can see the problem I am trying to solve. It is a pipe, which opens in to a space. I am trying to create a inflation layer aroud the corner. For different corners in my project the inflation layer is is created nicly arpund the corner. For some reason I can not create the infaltion in this area.
Does anyone have an idea what I could do?
Kind regards
Steven Timoney
December 26, 2018 at 4:23 pm
peteroznewman
SubscriberHello Steven,
I have inserted the image you attached above to this post because ANSYS employees on this site are not permitted to open attachments. Please use the Insert Image button on the toolbar on your posts.
Is this a 2D mesh?
I would try to slice the fluid body at the intersection and put the bodies into a multi-body part, then the inflation layer might not feather out.
Kind regards,
Peter -
December 27, 2018 at 4:27 pm
StevenTimoney
SubscriberHello Peter,
Thank you for your reply and thanks for the advice for the pictures.
It is a 3D-Mesh.
I tried slicing the fluid body at the intersection and put them into a multi- body part. Unfortunately, the mesh didn’t go around the corner. So, I united the two slices using the Boolean command.
Now the Mesh is the way I need it.
Thank you for your help.
Kind regards
Steven Timoney
December 27, 2018 at 5:18 pm
peteroznewman
I'm glad it's working now. Please click the Is Solution link to show that this topic is solved.
Kind regards,
Peter
- The topic ‘Inflation layer’ is closed to new replies.
4999
1676
1386
1248
.jpg?width=690&upscale=false)
