December 24, 2018 at 10:27 am
liangzheng63
SubscriberHello, everyone
I'm building a magnetization fixture for magnetizing a virgin Neodymiun magnet in Maxwell, after the magnetization process be solved, I wanna insert the magnetized magnet into another product simulation project, so how could I only use the magnet model, and do simulation with other project but not the magnetization fixture?
Is there some way that could just "take out" the magnet? if someone knows, please tell me, thanks.
Viewing 0 reply threads
- The topic ‘How to “take out” the model which was magnetized’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1487
1338
1188
