Ansys Learning Forum Forums Discuss Simulation Fluids Set up the flow solver Reply To: Set up the flow solver
Aras karimi
Hi Federico,
I checked and watched the above resources you mentioned. I still have a big difference in validating my results with experimental results. I even did some transient simulations to ensure the accuracy of my results, but there is still a big difference between my results and the experimental results.
I checked the solver setup hundreds of times to make sure I set everything up correctly. I initialize all simulations as hybrid.
Is it possible to change the initialization type to make a significant change in the results?
Regards
