Electronics
Electronics
i am getting an error which i am unable to understand to get rid of in parametric analysis
    • saumitrapalc
      But this error only comes for a parametric setup otherwise my model works fine for giving me the results of inductance calculation
       WPT_Saumitra_1 (CUsers/Alberto/Documents/Ansoft/)
        [error] Acis error: "Fail to cover lines. The given body is not a wire body! Make sure it is a wire body " (3:29:43 PM  Dec 10, 2018)
        [error] Coil1: CoverLine operation failed. (3:29:43 PM  Dec 10, 2018)
        [error] Coil2: CoverLine operation failed. (3:29:43 PM  Dec 10, 2018)
        Maxwell3DDesign1 (Magnetostatic)
          [info] Verify conduction path: Conduction path validate success. (3:49:40 PM  Dec 10, 2018)
          [info] Verify conduction path: Conduction path validate success. (3:49:53 PM  Dec 10, 2018)
          [warning] Adaptive Passes did not converge based on specified criteria. (3:50:27 PM  Dec 10, 2018)
          [info] Normal completion of simulation on server: Local Machine. (3:502 PM  Dec 10, 2018)
          [info] Parametric Analysis on ParametricSetup1 has been started. (3:502 PM  Dec 10, 2018)
          [info] A variation (mut_coup_x='0mm') has been requested using the following machines: Local Machine. (3:505 PM  Dec 10, 2018)
          [info] A variation (mut_coup_x='20mm') has been requested using the following machines: Local Machine. (3:50:40 PM  Dec 10, 2018)
          [error] Acis error: "Fail to cover lines. The given body is not a wire body! Make sure it is a wire body " (3:50:41 PM  Dec 10, 2018)
          [error] Coil1: CoverLine operation failed. (3:50:41 PM  Dec 10, 2018)
          [error] Coil2: CoverLine operation failed. (3:50:41 PM  Dec 10, 2018)
          [info] Verify conduction path: Conduction path validate success. (3:50:41 PM  Dec 10, 2018)
          [warning] Adaptive Passes did not converge based on specified criteria. (3:51:13 PM  Dec 10, 2018)
          [info] A variation (mut_coup_x='40mm') has been requested using the following machines: Local Machine. (3:51:18 PM  Dec 10, 2018)
          [error] Acis error: "Fail to cover lines. The given body is not a wire body! Make sure it is a wire body " (3:51:19 PM  Dec 10, 2018)
          [error] Coil1: CoverLine operation failed. (3:51:19 PM  Dec 10, 2018)
          [error] Coil2: CoverLine operation failed. (3:51:19 PM  Dec 10, 2018)
          [info] Verify conduction path: Conduction path validate success. (3:51:19 PM  Dec 10, 2018)
          [warning] Adaptive Passes did not converge based on specified criteria. (3:51:51 PM  Dec 10, 2018)
          [info] A variation (mut_coup_x='60mm') has been requested using the following machines: Local Machine. (3:51:56 PM  Dec 10, 2018)
          [error] Acis error: "Fail to cover lines. The given body is not a wire body! Make sure it is a wire body " (3:51:57 PM  Dec 10, 2018)
          [error] Coil1: CoverLine operation failed. (3:51:57 PM  Dec 10, 2018)
          [error] Coil2: CoverLine operation failed. (3:51:57 PM  Dec 10, 2018)
          [info] Verify conduction path: Conduction path validate success. (3:51:57 PM  Dec 10, 2018)
          [warning] Adaptive Passes did not converge based on specified criteria. (3:520 PM  Dec 10, 2018)
    • Sorceress Gia
      Have you tried manually changing the variables under 'HFSS -> Design Properties' to see if they generate a proper model that is not causing an intersecting or invalid body?
    • saumitrapalc
      actually i have done set up in MAxwell3DDesign and not in HFSS so in this i don't know how to remove this error but apparently it is solving and giving me the inductance value required for the coil that i had designed using draw line and assigning the material as copper
  • The topic ‘i am getting an error which i am unable to understand to get rid of in parametric analysis’ is closed to new replies.
