December 9, 2018 at 9:12 pm
Omarwahba
SubscriberHi everyone Iam new to ansys I was wondering is it possible to perform 2D topology optimization and how to ? -
December 10, 2018 at 4:38 am
peteroznewman
SubscriberIf you type ansys topology optimization 2D into Google, you will find this.
December 10, 2018 at 4:48 am
Omarwahba
SubscriberI already saw that and I draw a surface
Applied loads and boundary condition but when solving I get an error message that volume is equal to zero -
December 10, 2018 at 5:01 am
peteroznewman
SubscriberIf you want help with that problem, then reply with details on the model. Show screen snapshots of the surface, the loads, the boundary conditions, and all the topology optimization settings.Â
December 10, 2018 at 5:38 am
December 10, 2018 at 9:04 am
jj77
SubscriberYou are most likely using plane stress without defining a thickness for the part.
This is clearly seen in the question mark next to your geometry on the Outline tree structure. Go into the SYSsurface and assign a thickness for your part.
December 10, 2018 at 12:19 pm
peteroznewman
SubscriberIn addition to what jj77 said, In Workbench, on the Geometry cell, you have to set the Analysis Type to 2D before you start Mechanical to define loads and supports. See this post.
December 11, 2018 at 7:04 am
Omarwahba
SubscriberThanks it worked -
January 19, 2020 at 7:12 am
Maulik
SubscriberHello, i am performing topological optmization for 2d truss structure and am able to perform static structural analysis perfectly. But, for topological optimization, i am not able to use line body for optimization even though i have given a circular cross section area for the body. can you suggest any possible reason for the same
January 19, 2020 at 9:55 am
peteroznewman
- The topic ‘2D topology optimization’ is closed to new replies.
6239
