Ansys Learning Forum Forums Discuss Simulation General Mechanical Unable to modify exported deformed geometry exported from Static Structural Reply To: Unable to modify exported deformed geometry exported from Static Structural
yu272
Hi Sampat,
Could you be more specifc on how the "fix" works? I imported the pmdb file into SpaceClaim and the deformed geometry now shows as a solid with mesh. Also, I lost the previously defined name selection, faces and edges on the geometry. Does that imply that I need to redo the sketching in SpaceClaim based on the geometry I imported?
Thank you!
Eric
