Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Selection logic In apdl › Reply To: Selection logic In apdl
November 30, 2023 at 4:41 pm
dlooman
If you issued allsel before the cerig command how is it possible that the independent node wasn't selected!? If you say there is a one to one correspondence between the element real constant set number and the element type numbers you specified, the only explanation is that the second one was a reselect. Why didn't you use ESEL,s for the type numbers like you did for the real constant numbers?
