Ansys Learning Forum Forums Discuss Simulation General Mechanical Memory Allocation of RAM and HDD Reply To: Memory Allocation of RAM and HDD
Aniket
It seems from the analysis that both the analyses are taking around 15 GB RAM to solve, the only difference on the workstation seems to be using HDD instead of SSD. It also seems that you have SSD on C: on the workstation, can you use that instead? You can not simply use RAM instead of storage, as you would require bare minimum storage for storing files.
for more info please check:
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v232/en/ans_per/perioansys.html
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v232/en/ans_per/per_measuring.html
-Aniket
Forum Rules & Guidelines
