Ansys Learning Forum Forums Discuss Simulation Photonics Questions regarding an example Reply To: Questions regarding an example
Mariah Ha
Thank you for the reply. The article suggests using the front monitor reflection when I have source injection errors, which come mainly from the injection at an angle. However, the solar cell example source is not injected at an angle and is a simple plane wave. This is why I was asking about the cause of using the  front monitor for reflection in this case. The second point is, the article mentions taking the reflection 1 minus the transmission from the monitor. However, the script of the example takes 1+transmission. Could you please clarify these two points ? Thank you.
