Ansys Learning Forum Forums Discuss Simulation General Mechanical Failed Mesh of a prismatic body made of a sandwich honeycomb structure Reply To: Failed Mesh of a prismatic body made of a sandwich honeycomb structure
Adrián Morgades
Yeah, I exported the assembly from CATIA in STEP and IGS format and it makes no difference. The problem is that when importing to Ansys, there are some voids that are generated ialong the thickness of the different sheets and honeycomb structures, and I don't know why is that happening.
Nonetheless, I'll try slicing the body into different parts and see if it works better the mesh. Thanks!
