November 28, 2023 at 3:56 pm
Damian Rodolfo
SubscriberAs stated above I am trying to mirror a component using script but it doesnt seem like I can. I record doing it by hand, but the record function in scripting doesn't pick it up. I can mirror faces and bodies and it will, but not when i try mirroring components. Is this a bug?
November 29, 2023 at 5:47 am
Devendra Badgujar
Forum ModeratorHello Damian,Â
Let me check and get back to you on this.Â
DevendraÂ
November 30, 2023 at 10:08 am
Devendra Badgujar
It was not possible to record the mirror components till API V232 version. It will be possible to do so in API V241 version in the next release.Â
Thank you,
DevendraÂ
November 30, 2023 at 2:59 pm
Damian Rodolfo
Subscriberfor those wondering i figured out what command it was:
# Mirror
selection = Component
mirrorPlane = DatumPlane1
options = MirrorOptions()
result = MirrorComponents.Execute(selection, mirrorPlane, Info#)
# EndBlock
- The topic ‘Is there a way to mirror a component using script in spaceclaim?’ is closed to new replies.
