Archiving: “The project contains one o more files that need repair”
    • domenech
      I'm trying to archive a project. However, whenever I try, I get this message: "The project contains one o more files that need repair. Do you want to archive anyway". All the simulations are finished and look ok.
      How can I repair the files? I've tried to archive anyway and the project seems empty. Google only yields an unanswered forum post here.
      Someone moved the geometry files to another folder, but I've moved them back.
    • Sampat Kumar
      Hi Carles,
      Will you please check if all the required files are available or not in the file section of the Ansys Workbench? If some files are missing, then please repair them and then try to archive the project again.
      Sampat
    • Aniket Chavan
      In Workbench Click on View>Files
      This will show all the files that require repair highlighted in red:
      Right click on them one by one and click repair and select the file from exact file path:
      -Aniket
      Forum Rules & Guidelines
    • domenech
      Thank you, Aniket and Sampat.
      I've repaired all the geometry files and I don't see other files marked in red. However, when I make a new archive, the result is the same: When opening I get the message "Failed to extract the project archive 'XXXXXXXX' the archive may be invalid"
  • The topic ‘Archiving: “The project contains one o more files that need repair”’ is closed to new replies.
