November 27, 2023 at 6:48 pm
December 5, 2023 at 10:21 am
Praneeth
Ansys EmployeeHi Imtiaz,
Thank you for reaching out to the Ansys Learning Forum. Your patience on this is much appreciated.
Please provide more details to help us serve you better - which version and design type is used, which guidelines you are referring to.
It is hard to comment on the correctness of the results. Did you observe any difference in results between the models with and without the solder mass thickness?
Best regards,
Praneeth.
- The topic ‘ACIS Error after adding solder mask thickness in the HFSS design!!!’ is closed to new replies.
Ansys Innovation Space
1388
1188
1095
1015
