Extract a 3D heat flux profile to feed into transient thermal analysis
    • Kursad Sezer
      I am working on a transient thermal analysis related to laser beam scanning. I've encountered a challenge in extracting a 3D heat flux profile from a thermal analysis and feeding into a new transient thermal module for further analysis. Any guidance to streamline our approach is much appreciated.
      Thanks
      Kursad
    • erik.kostson
      Hi
      Not clear what you want to do here and why you need to do this (I can not follow what you are trying to do here) - so in order for forum members to provide feedback, you would need to provide much more detail on what, and why, and any other info that might be good to have.
      All the best
      Erik
    • Kursad Sezer
      Thank you for responding to my query on the Ansys forum regarding my transient thermal analysis project.
      To provide further clarification, my project involves simulating a constant temperature source, representing laser beam scanning, for annealing CZTS coated on Mo film. The primary challenge is extracting a 3D heat flux profile from this thermal analysis and then integrating it into a new transient thermal module for more detailed examination. The objective is to achieve more homogeneous heating compared to the traditional Gaussian beam annealing process.
      Thanks
      Kursad
  • The topic ‘Extract a 3D heat flux profile to feed into transient thermal analysis’ is closed to new replies.
