Ansys Learning Forum Forums Discuss Simulation Electronics Importing complex 2D antenna drawing to ANSYS Reply To: Importing complex 2D antenna drawing to ANSYS
Praneeth Munaga
Thank you for reaching out to the Ansys Learning Forum.
It is possible to draw the geometry in AEDT HFSS itself if you are drawing this model in Matlab using design equations. Please go through “Drawing an Equation-Based Curve” section in the HFSS help document available under the Help menu for more detailed information.
Best regards,
Praneeth.
