Ansys Learning Forum Forums Discuss Simulation Electronics Parallel resonace coil array Reply To: Parallel resonace coil array
Praneeth
Kindly let us know whether you want to run a circuit or 3D simulation and your end goal. Please check my comments/suggestion as below:
  1. In the schematic the coils and capacitors are in parallel connection, but in the 3D model your coils are connected in parallel but arranged in an array fashion. Does your analysis require you to keep them in parallel?
  2. How are you ensuring that the Tx and Rx sides are coupled?
Kindly elaborate your design goals to help us serve you better.
Best regards,
Praneeth.
