Ansys Learning Forum Forums Discuss Simulation Platform Failed to validate credentials in RSM Reply To: Failed to validate credentials in RSM
MangeshANSYS
Please check the Software Guides for Ansys when using the cluster in question. Perhaps is is necessary to load a module so Ansys becomes available in yoru user login before you can run Ansys ?
you can try adding the relevant module load command to your .bashrc file or to this file /ansys_inc/v231/Config/tools/linux/rsm_env_profile
