Ansys Learning Forum Forums Discuss Simulation General Mechanical matrix coefficient ratio exceeds 1e8 Reply To: matrix coefficient ratio exceeds 1e8
Rukmini Sai Rupa Sri Mada
This is one of the warnings i am getting during the simulation
 The eigenproblem is ill-conditioned (relative residual from test linear solve: 6.084859E-03).  The accuracy of the solution may not be satisfactory.  Modifying the initial value of the frequency shift  (FREQB in the MODOPT command) or changing the boundary conditions of the model might solve the problem.
How do I address this?
