November 18, 2023 at 12:30 am
Pierre Cautela
SubscriberHi Ansys community I would need a hand on an issue I can't deal with. I made a simulation on a Catia part I exported with IGS format on ansys CFD and I just can't make it work once I've passed the meshing. I followed CFD Baba's tutorial right here
?si=UlhG0rS_gjn2ON_v that was really useful but once I've got to set up it's all gone south. First I see that I don't have mesh matching solid and than I see that I can't put velocity outlet on outlet so I know it's not irght but I don't know what to do and then I just can't have results. I have this error messageÂERROR CCL validation failed with message: Error: Value '' is not allowed for parameter /VIEW:View 1/Highlight Type Error: Parameter '/VIEW:View 1/Axis Visibility = ' must be type Logical Error: Parameter '/VIEW:View 1/Ruler Visibility = ' must be type Logical Error: Value '' is not allowed for parameter /VIEW:View 2/Highlight Type Error: Parameter '/VIEW:View 2/Axis Visibility = ' must be type Logical Error: Parameter '/VIEW:View 2/Ruler Visibility = ' must be type Logical Error: Value '' is not allowed for parameter /VIEW:View 3/Highlight Type Error: Parameter '/VIEW:View 3/Axis Visibility = ' must be type Logical Error: Parameter '/VIEW:View 3/Ruler Visibility = ' must be type Logical Error: Value '' is not allowed for parameter /VIEW:View 4/Highlight Type Error: Parameter '/VIEW:View 4/Axis Visibility = ' must be type Logical Error: Parameter '/VIEW:View 4/Ruler Visibility = ' must be type Logical Error: Value '' is not allowed for parameter /VIEWPORT MANAGER/Background Type Error: Value '' is not allowed for parameter /VIEWPORT MANAGER/Background Colour Type Error: Value '' is not allowed for parameter /VIEWPORT MANAGER/Background Image Type Error: Value '' is not allowed for parameter /VIEWPORT MANAGER/Background Image Error: Value '' is not allowed for parameter /VIEWPORT MANAGER/Background Image Mapping Error: Value '' is not allowed for parameter /VIEWPORT MANAGER/Viewer Eye Point Error: Parameter '/UNIT SYSTEM/Update Units to Preferred = ' must be type Logical Error: Invalid Option parameter '' in /MASS FLOW CALC OPTION ON PHYSICAL SURFACES
So yeah if you could give me a hand that would be awesome. Thank you by advance
November 20, 2023 at 4:19 pm
Federico
Ansys EmployeeIt looks like there is something wrong with your mesh.Â
It might be easier for you to import your .IGS file into Fluent Meshing and use our Watertight Geometry Workflow.
Here are a few workshops to get you started: Tutorial on Watertight Geometry Workflow | Ansys Courses
- The topic ‘Issues getting results on a simulation with a geometry from CATIA’ is closed to new replies.
- affinity not set
3907
1414
1256
1118
1015
