Ansys Learning Forum Forums Discuss Simulation General Mechanical Meshing around a semi elliptical crack; warning: during crack meshing error Reply To: Meshing around a semi elliptical crack; warning: during crack meshing error
Elena Maier
thank you so much. I can´t open the links, that doesn´t work.
I got that a little to late, I am already really far in my validation process and it is difficult to do it now with a total different crack type. Because in the beginning I thougt it could work with that crack.
Is the rest of my meshing/ contact definition realistic/good like that?
And do you have an idea how I can mesh this, to get still ok results?
It would help me a lot, thanks for your answer in advance,
Best regards
Elena
