November 16, 2023 at 2:33 pm
Federico Parisini
Subscriberhi, I really need help understanding how to implement a fatigue simulation of threaded connections. i have correctly defined the material of the screws (S-N curves).
The point is that performing a fatigue analysis on a two-step analysis, in which in the first step I have the bolt pretension and in the second the application of the loads, makes me doubt whether the software considers that the preload is also applied cyclically.
So I eliminated the bolt pretensions and only considered the loads, but I'm not sure it's right not to consider the preload of the screws. How can I consider the static load of the screws and the cyclic loads at the same time? thank you.
November 16, 2023 at 3:58 pm
ErKo
Ansys EmployeeDuplicate - use first post:
/forum/forums/forum/discuss-simulation/structures/
- The topic ‘Fatigue Analysis of bolts’ is closed to new replies.
1307
