Ansys Learning Forum Forums Discuss Simulation General Mechanical Y-Direction of Point Mass Reply To: Y-Direction of Point Mass
Saumadeep Choudhury
I assume you're asking what will happen if you position your point mass in different vertical locations along the y-axis.
The answer to this is that it will introduce a moment that will be proportional to the distance in the Y-axis between the point mass and the slab.
Saumadeep
