Generate CSV file containing load history to XML file to import Ansys Mechanical
    • Anh Van
      Hi folks,
      I am trying to import file XML as input of load history data to the force under tabular format. Of course, I can type by hand each element of the tabular as well as copy and paste from file csv containing the target table already. But I wonder if there is a way to convert directly from the CSV file to an XML file, then I can import directly the XML file.?
      It would be appriciated if you guys could give me some suggestions, even the example of an XML file containing a table.
      For example, I want to import XML file represented the table below.
      Time(s)X(N)Y(N)Z(N)
      00-100000
      10-100000
      20-200000
      30-3000000
      Thank you so much!
    • Aniket Chavan
      You can get the format easily by creating a dummy load, and then adding some random values and clicking the export button. (which is just below the import).
      -Aniket
      Forum Rules & Guidelines
  • The topic ‘Generate CSV file containing load history to XML file to import Ansys Mechanical’ is closed to new replies.
