Ansys Learning Forum Forums Discuss Simulation Fluids Diverging Results with density based solver Reply To: Diverging Results with density based solver
Federico
I don't see any issues with the information that you are giving me. You can try reducing Turbulent URF and/or the time step to see if this helps with stabilization.
Side note: the pressure-based solver nowadays may be just as accurate even for flows M ~ 3.
