Ansys Learning Forum Forums Discuss Simulation General Mechanical Scripting in ANSYS Mechanical Reply To: Scripting in ANSYS Mechanical
ErKo
Hi
Can you explain what you want to do and why ?
Also you said "to sort based on their location to respective named selection"?
So in each named selection it will include one or multiple beams depending on what (the position say centroid)?
Try to write a pseudo code on what you want to do and then you can find which commands to use.
https://builtin.com/data-science/pseudocode
All the best
Erik
