November 13, 2023 at 7:21 pm
November 15, 2023 at 1:33 pm
Saumadeep Choudhury
Forum ModeratorHi,
I don't see any question here. Would you kindly post here the query you have?
Saumadeep
November 15, 2023 at 9:56 pm
Galaxy
SubscriberPlease see the updated question.
November 16, 2023 at 10:36 am
Saumadeep Choudhury
Forum ModeratorHi,
I assume you're asking what will happen if you position your point mass in different vertical locations along the y-axis.
The answer to this is that it will introduce a moment that will be proportional to the distance in the Y-axis between the point mass and the slab.Regards,
Saumadeep
November 16, 2023 at 12:52 pm
Galaxy
SubscriberIf I have a small regular plate sitting on top of the beam, what should my y position be? Like 0?
November 16, 2023 at 1:01 pm
Saumadeep Choudhury
Forum ModeratorIf the thickness of the plate you mentioned is not significant, then the Y-axis distance between the Beam and the point mass can be zero.
November 16, 2023 at 1:37 pm
Galaxy
SubscriberTo my understanding, the y-axis distance is the distance between the center of mass of the point mass to the surface of the beam, is that correct?
- The topic ‘Y-Direction of Point Mass’ is closed to new replies.
4888
1587
1386
1242
