November 25, 2018 at 9:41 am
TokarZak
SubscriberHi, Pls help me to solve this error, wich i have after initialization.
Initialize using the hybrid initialization method.
Checking case topology...Â
-This case has both inlets & outletsÂ
-Pressure information is available at the boundaries
iterscalar-0scalar-1
    Stabilizing ads-0 to enhance linear solver robustness.
Divergence detected in AMG solver: ads-0
Divergence detected in AMG solver: ads-0 1 1.000000e+00 1.000000e+00
27.069178e-151.032749e-07
31.247592e-155.052188e-08
42.017610e-156.174646e-09
58.277866e-161.961420e-09
66.685306e-166.028668e-10
73.816698e-163.438961e-10
82.523928e-161.602407e-10
93.202773e-161.096430e-10
104.077587e-165.657155e-11
Hybrid initialization is done.
 Error at Node 6: floating point exception
Error at Node 11: floating point exception
Error at Node 2: floating point exception
Error at Node 0: floating point exception
Error at Node 7: floating point exception
Error at Node 5: floating point exception
Error at Node 8: floating point exception
Error at Node 9: floating point exception
Error at Node 1: floating point exception
Error at Node 3: floating point exception
Error at Node 10: floating point exception
Error at Node 4: floating point exception
Error at host: floating point exception
===============Message from the Cortex Process================================
Compute processes interrupted. Processing can be resumed.
Error: floating point exception
Error Object: #f
Mesh Check
Domain Extents:
  x-coordinate: min (m) = -3.284205e-01, max (m) = 9.376061e-01
  y-coordinate: min (m) = -1.214897e+00, max (m) = 1.214805e+00
  z-coordinate: min (m) = -1.300000e+00, max (m) = 1.214776e+00
 Volume statistics:
  minimum volume (m3): 3.039545e-15
  maximum volume (m3): 2.135412e-04
   total volume (m3): 2.186046e+00
 Face area statistics:
  minimum face area (m2): 5.922891e-12
  maximum face area (m2): 3.296252e-03
 Checking mesh.....................................
Done.
November 25, 2018 at 9:46 am
November 25, 2018 at 10:30 am
Mostafa22
Subscriberdear TokarZak,
I think for your model, you have some fine contact regions. So in the mesh interfaces, you can modify these contact regions into a coupled wall and mapped as well as check the material properties.
I wish these suggestions help you
regards,
mostafa
November 26, 2018 at 6:31 am
Keyur Kanade
Ansys EmployeeThe image is not so clear.
If you have those contact regions -Â
Go back to design modeler. Select all bodies in the model tree and create a single part. This will give conformal mesh between different bodies.Â
Then mesh it and then come to fluent.Â
https://www.youtube.com/watch?v=IO4ZtwZdD2I
November 26, 2018 at 6:32 am
Keyur Kanade
Ansys EmployeeAlso please check quality of the mesh. The min ortho quality should be more than 0.1.
The min volume is very less. So pleas use double precision.Â
November 26, 2018 at 6:55 am
seeta gunti
Ansys EmployeeHello,
I guess solver is diverging in UDS. Please run the continuity and momentum equations first. After flow gets stabilized, turn on UDS. Reduce the URFs and initially run with first order then change to second order.
Seeta
December 3, 2018 at 1:46 pm
TokarZak
SubscriberHi, thaks a lot for response. But i dont use UDS.
December 3, 2018 at 2:04 pm
Amine Ben Hadj Ali
Ansys EmployeeCould you please elaborate on your problem physics and problem setup?
December 4, 2018 at 1:29 pm
TokarZak
SubscriberHi, i have really big model, but with simple setup: Without Energy eq. viscous model is laminar. I was set pressure on inlet and out let, choose material like water-vapor.
i will add link for CASE:
https://drive.google.com/open?id=1JXFRIWzWPdkpLnpkHPGe8g0M2hDXItQq
Best regards
Zak
December 4, 2018 at 4:26 pm
TokarZak
SubscriberOk, It was solved. Thanks a lot.
December 5, 2018 at 3:00 am
Keyur Kanade
Ansys Employeecan you please mark this as 'Is Solution' to help others on forum.Â
June 26, 2019 at 2:30 pm
aliazzam
Subscriberwhat was the solution please ????????
June 26, 2019 at 2:34 pm
aliazzam
Subscriberhow did u do it please ???
June 26, 2019 at 2:54 pm
Forum ModeratorPlease post in a new thread with details of your problem.Â
- The topic ‘Error: floating point exception’ is closed to new replies.
3140
1007
935
858
792
