November 22, 2018 at 7:09 pm
lucaavv
SubscriberHi
I'm tryng to model a fluid disk and i need to separate it in smaller disks for improving the mesh.
Firstly I created the whole disk body in designmodeler, frozen it and than I separated it by the "slice by plane" function, created the mesh and went to FLUENT for the computation. At this point I have a problem due to the presence of two "wall" at the two disks interface of the separation zone in the "Bonduary Condition" section.
I think the problem is in the "connections" section of the "Meshing" editor.
How can I remove these wall's, or how can I give continuity to the fluid body?
Thank you all
November 23, 2018 at 5:00 am
Keyur Kanade
Ansys EmployeeYou need to have share topology between two bodies.
Please open Design Modeler
Select two bodies in model tree - Right Click - Create a new part.Â
Then go to mesh and then solver.Â
Please check following video for share topology function.Â
https://www.youtube.com/watch?v=IO4ZtwZdD2I
If you find this as solution, please mark this post as 'Is Solution' to help others.Â
- The topic ‘contact of two fluid bodies’ is closed to new replies.
5864
1305
