Preprocessing
Preprocessing
Best meshing strategy
    • Alexandre11
      Hello everyone.
      Can someone suggest the best meshing strategy for the attached geometry?
      regards
    • Sandeep Medikonda
      I don't see any attachment. Please go over the video tutorials provided in the youtube channel.
      https://www.youtube.com/watch?v=P19GOTQWmc0&list=PL0lZXwHtV6OlbZcma3GztaXO5svGskqIy
      There are also a lot of tutorials provided in the Help Manual.
    • Alexandre11
      Thanks for your reply.
      the geometry is attached here
      https://drive.google.com/uc?id=1eT-I9OdrVliQp5Sv-EWrO4TTy5fUyND5&export=download
    • Keyur Kanade
      Please insert some images of the geometry. As ANSYS we are not able to download attachments.
      You can also check following.
      https://www.youtube.com/watch?v=RELLrEJ9chg
      https://www.youtube.com/watch?v=sZIX3CJkWBE
    • Alexandre11
      the image of geometry is attached.
    • Keyur Kanade
      This a simple geometry and you can create a hex mesh in it using sweep method.
      Please have a look at following video for the same.
      Please make sure that you create a single part in DM and then proceed to meshing so that the geometry will be decomposed with inner bodies automatically by sharetopology.
      https://www.youtube.com/watch?v=Uw-SK2y2w9M
      https://www.youtube.com/watch?v=CQ7ISCcRecQ
      https://www.youtube.com/watch?v=IO4ZtwZdD2I
Viewing 5 reply threads
  • The topic ‘Best meshing strategy’ is closed to new replies.
