November 19, 2018 at 11:45 pm
sherifrashwan247
SubscriberHow I can define bubbles in the geometry domain?
How i can simulate the acoustic cavitation bubble?
November 20, 2018 at 4:21 am
Keyur Kanade
Ansys EmployeeYou may want to look at following
https://www.youtube.com/watch?v=8tRjQRErey8
November 20, 2018 at 4:28 pm
sherifrashwan247
Subscriber@kkanade
Thank you very much for the video, my question is that: should i define a spherical bubble in the geometry or it should be created on its own through simulation?
Yours Sincerely,
Sherif
November 21, 2018 at 5:52 am
Keyur Kanade
Ansys EmployeeYou can define bubble dia in Fluent. No need to create it in geometry.
December 17, 2018 at 5:06 pm
sherifrashwan247
SubscriberThe goal is to model cavitation generated using a horn that vibrates in a bath of liquid and calculate the maximum collapse pressure produced.
I dont know how to enable the acoustic model and how to specify the boundary conditions?
The geometry is very simple 2D with one side oscillating by a certain frequency? should i apply the same model in the video while enabling the acoustic model as well? what do you kindly recommend?
December 17, 2018 at 5:18 pm
Amine Ben Hadj Ali
Ansys EmployeeYou will need to go 3d, use high resolution mesh of LES or better quality to get a well resolved pressure field to accurately describe cavitation and use a scheme to track the interface.
December 17, 2018 at 5:23 pm
sherifrashwan247
Subscriberhi Sir, thanks do you have a sort of steps to follow to setup the model please?
Yours Sincerely,
Sherif
December 17, 2018 at 5:30 pm
Amine Ben Hadj Ali
Ansys EmployeeYou might find some scientific papers dealing with it. You will see that some them are just using URANS approaches which might be considered as first step for very detailed analysis
December 17, 2018 at 5:35 pm
Amine Ben Hadj Ali
Ansys EmployeeCFD Modeling of Low, Medium and High Frequency Ultrasound Waves Propagation Inside a Liquid Medium as example. Good luck
December 17, 2018 at 5:49 pm
sherifrashwan247
SubscriberIs that a publication? Can you please attach the link because i can not find it online?
Yours Sincerely,
Sherif
December 17, 2018 at 5:55 pm
sherifrashwan247
Subscriberhow to specify a free surface boundary condition? Is that a wall or something different?
December 17, 2018 at 6:47 pm
Amine Ben Hadj Ali
Ansys EmployeeFree slip wall as general simplification.
December 17, 2018 at 6:49 pm
Amine Ben Hadj Ali
Ansys EmployeeYes publication. I do not share papers here.
- The topic ‘Acoustic Cavitation Bubble’ is closed to new replies.
- affinity not set
3862
1414
1221
1118
1015
