November 5, 2023 at 5:50 am
yi wen
Subscriber how to made 'enabled' change to right by lumerical script? the position is 'interface reference position 'in geometry of RCWA.
November 5, 2023 at 5:53 am
November 7, 2023 at 5:14 pm
Amrita Pati
Ansys EmployeeHi Yi,
You can set the interface position using the set or setnamed script commands for the "interface reference positions" property. The argument is a cell array of cell arrays where there is an inner cell array for each enabled reference position. The cell array for the interface has three fields: name, type and interfaces. So an example cell array would be:
{{"::model::rectangle", "max", 1},{"::model::rectangle", "min", 1}}
An example script command to set this property would be:setnamed("RCWA", "interface reference positions", {{"::model::rectangle", "max", 1},{"::model::rectangle", "min", 1}});Regards,
Amrita
- The topic ‘RCWA’ is closed to new replies.
1890
1414
1304
