multi-component multiphase fluid flow simulation
    • hagos.gebru
      Hello dears, I need to simulate the simple distillation process containing water, ethanol, stillage, and air using fluent. so which approach of multi-phase model should i use for best computational time and accuracy?
      regards,
    • Prashanth
      since it is a mixture, you can think of using a partial pressure driven mass transfer model. Fluent has some options. You can read through this section: 14.7.7.2. Equilibrium Models
    • hagos.gebru
      Thank you sir, I couldn't get the referance and could you please make it free accessed?
    • hagos.gebru
      Open Help in the solver and paste the link into that browser. Or open Help & click on the link if both open in the same browser. The software contains a token/cookie/biscuit to bypass the security stage.
    • hagos.gebru
      Thank you got it.
Viewing 5 reply threads
  • The topic ‘multi-component multiphase fluid flow simulation’ is closed to new replies.
