November 12, 2018 at 6:56 pm
Rizwan
SubscriberÂ
For generating a mesh of three equal element size of a rectangular geometry having length 3 meter and breadth 1 meter, I used edge sizing twice for horizontal and vertical boundaries.Thereafter I went for face sizing with element size 1m but am unable to see any mesh on the rectangular face.Kindly advise.
November 12, 2018 at 7:35 pm
Karthik Remella
AdministratorHello,
Could you please share the error message from ANSYS meshing? It is hard to make out from your screenshot.
Thank you.
Best Regards,
Karthik -
November 13, 2018 at 12:30 am
peteroznewman
SubscriberRizwan,
Click on the Edge Sizing mesh control and look in the Details window. There is a row called Behavior. The default is Soft, which means the mesher takes the number of elements as a suggestion that it can ignore. Change the Behavior to Hard and the mesher will respect the Edge Sizing input.
Peter -
November 13, 2018 at 1:42 am
Rizwan
SubscriberDear Peter
I am always using the ‘hard’ behaviour.Something else is being missed out.
Regards
Rizwan
November 13, 2018 at 1:53 am
Rizwan
Subscriber‘A mesh control is not associated to any geometry’
Regards
Rizwan
November 13, 2018 at 3:06 am
Keyur Kanade
Ansys EmployeeCan you please insert some zoomed in images for your controls.Â
Please make sure that you use no. of divisions in edge sizing. Please use same no. of divisions on opposite edges.Â
November 13, 2018 at 3:29 am
Aniket Chavan
I am unable to see the details for all the methods that you are using but I would do this with following 3 local sizings:
November 13, 2018 at 3:48 pm
Rizwan
SubscriberThanks Aniket
- The topic ‘3 element rectangular mesh-v18.2’ is closed to new replies.
6475
