November 9, 2018 at 6:50 pm
pnvk95
SubscriberHello
My simulation is running slowly because it is reporting the DPM data in the console after every time-step (part of report attached below). I want it to report every 1000 time-steps instead. How can I make sure the console doesn't report so often?
CONSOLE OUTPUT SAMPLE
Updating solution at time level N... done.
Injecting 1000 particle parcels with mass 8.75e-14 at t = 0
 iter continuity x-velocity y-velocity   energy   time/iter
Advancing DPM injections ....
number tracked = 1000, escaped = 0, aborted = 0, trapped = 0, evaporated = 0, incomplete = 0, incomplete_parallel = 0
Flow time = 0.0005s, time step = 1
99999 more time steps
Flow time = 0.001s, time step = 2
99998 more time steps
Flow time = 0.0015s, time step = 3
99997 more time steps
November 12, 2018 at 7:30 am
Keyur Kanade
Ansys EmployeeAre you using unsteady flow with unsteady particle tracking?
November 13, 2018 at 5:42 pm
pnvk95
SubscriberYes. Transient problem with unsteady particle tracking.
November 14, 2018 at 4:23 am
Keyur Kanade
Ansys EmployeeYou may need to change dpm iteration interval.Â
- The topic ‘Console reporting for DPM’ is closed to new replies.
- affinity not set
3862
1414
1220
1118
1015
