November 8, 2018 at 9:49 am
Elias
SubscriberI Can't section the geometry by using just section plane even if I can draw a line on the body.Any idea how to do on 18.2version please? -
November 8, 2018 at 9:55 am
Rohith Patchigolla
Ansys EmployeeHello Elias,Â
Can you please post some pictures to explain the problem better?
Best regards,
Rohith
November 8, 2018 at 10:14 am
Elias
SubscriberHello rohith.the step is on edx course the geometry is bike crank .but I can't section it as the shown step on the course. -
November 8, 2018 at 11:15 am
Rohith Patchigolla
I do not have access to this course. Please attach a snapshot of Mechanical, where you have created a section plane (which is active) and where it is not working as expected.Â
I attached a snapshot using section plane at my end. Is your section plane active (check box next to section plane, as highlighted below in red box)
Best regards,
Rohith
November 8, 2018 at 11:37 am
Forum ModeratorThe panel may not be on, if not the button to activate it is in the middle of the top row of buttons in Rohith's image (just to the right of Show Errors).Â
November 8, 2018 at 12:45 pm
Elias
SubscriberIt was active when I post my question first but it is not active now on the upper middle position and left lower. -
November 9, 2018 at 1:18 am
Sandeep Medikonda
Ansys EmployeeElias,
You might have to toggle the Sections window. Please see here.
If it's greyed out, please see this post.
If nothing works you might want to use Reset Layout.Â
Sandeep -
November 9, 2018 at 10:56 am
Elias
SubscriberHow could I do that reset layout? -
November 9, 2018 at 11:15 am
February 16, 2023 at 5:53 am
sanket25
SubscriberHow can I create section plane exact from any primary plane?
March 7, 2023 at 4:45 pm
shabdali Ashwit
SubscriberHello
How can I create a section plane with a certian offset distance?
- The topic ‘section plane’ is closed to new replies.
6119
