Kampus Merdeka Belajar
Ask questions related to general and focused sessions.
Import Engineering Data
    • Syauqi Nur Rachman
      Hello, I am having trouble inputting engineering data for the LARGE STRAIN NECKING OF A TENSILE BAR SPECIMEN simulation. Where I have input data from excel and will import geometry, the Aluminum material is still undefined and the graph is also different from the example. Related to this problem, is there a solution? thank you
    • Raihan Lutfianto
      Hi Syauqi. This common problem usually happens due to incorrect copy-paste process from Excel to Ansys. Have you checked that both Excel and Ansys use "commas" instead of "dots"? Also, the given Excel needs to be converted from one column to two columns. Please recheck the Excel file before copying it into Ansys.
  • The topic ‘Import Engineering Data’ is closed to new replies.
