October 28, 2023 at 5:37 pm
October 28, 2023 at 6:58 pm
peteroznewman
SubscriberIn SpaceClaim, you would select the face and type Ctrl-C, Ctrl-V to copy the face and paste a surface. Then you could delete the solid.
October 28, 2023 at 7:06 pm
Jacob Ellis
SubscriberHi Peter. Not for a closed surface like a sphere. It simply pastes another 3D body even if you only have 1 Face selected. I tried in both Spaceclaim and Discovery.Â
October 28, 2023 at 7:17 pm
peteroznewman
SubscriberI see you are correct. A workaround is to create a plane to split the sphere into two hemispheres, then Detach All will work and you will end up with 2 domes and two circular flats. Delete the circular flats then use the Share button on the Workbench tab. Mechanical will mesh the spherical surface without an issue.
October 28, 2023 at 7:22 pm
Jacob Ellis
SubscriberTrue. Thanks for the workaround. Share Topology would work. I guess there is a deep reason in the Geometry algorithms (that I don't understand) why closed surfaces can't exist without automatically converting to a 3D Solid. Otherwise, it's a bit annoying that you need to bring in a multi-body part to the solver for this to work. But tolerable. Thanks and have a great weekend.
- The topic ‘Make a Spherical Shell from Sphere Primitive’ is closed to new replies.
5824
1305
