Ansys Learning Forum Forums Discuss Simulation Electronics How Ansys Maxwell consider fringing flux effect on inductor calculation? Reply To: How Ansys Maxwell consider fringing flux effect on inductor calculation?
Navya Chode
Hi Sadegh,
Ansys Maxwell accounts for fringing flux. Make sure you have region setup and is sufficient enough in case of application where the most of the flux is not confined with in the geometry.
You may need to increase the region padding to get the accurate results.
Navya
