Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Floating License Issue › Reply To: Floating License Issue
Hello Engineer,
Firstly, I want to express my gratitude for your assistance in addressing this matter. I apologize for the delay in my responses due to personal reasons.
I have a question regarding the ANSYS licensing configuration. If I assume the server's IP address is "166.111.222.221," would it be correct to add "SERVER=1055@166.111.222.221" to the "ansyslmd.ini" file? Additionally, when modifying the environment variable, should I change it to "166.111.222.221"? If I follow these steps and the issue remains unresolved, what should be the next course of action?
Thank you for your continued support and guidance.Â
Best regards,
