Ansys Learning Forum Forums Discuss Simulation 3D Design Large surface problem Reply To: Large surface problem
Kacper Wagner
Hi Atharv!
Sure! I'm trying to simulate the aerodynamics of residential estate. I have a few buildings and would like to create an air volume around them.
So, the volume should be based on a rectangle with dimensions of 1200x600 meters.
I tried to enclosure option, but it doesn't work. Also, a large surface doesn't work.
