Ansys Learning Forum Forums Discuss Simulation General Mechanical AnsysWBU.exe encountered a problem. A diagnostic file has been written Reply To: AnsysWBU.exe encountered a problem. A diagnostic file has been written
Jeongwon Kim
Do you mean by "options window" that can be access by Tools -> options at top above tab? I can't see any option window at file tab.(2023R2)
And I can't find "analysis setting and solution" nor "analysis data management" section at the option window approached by tool tab. Perhaps you are saying about solution process section?
Thank you.
